wnjj
Apr 11, 2019Explorer II
MrWizard wrote:
maybe i missed it
but i did not read where he says the NEW Fan is not working
only that LIGHTS 'down stream' from the replaced fan are not working
no blown fuses, no loose ground/NEGATIVE wire in the fuse panel
sounds like he mixed up one or two wires
I think you missed this:
OP wrote:
When I attach the Temporary ground the 5 lights work as they should (I don't know about the New Vent Fan Motor as I have not tried to put back in operation).
It’s an open ground for sure. The only mystery to him was why there was 12V on the ground wire prior to the temporary attachment. The answer is that the 12V passes right through the light bulb filament when the ground is floating.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
