steved28
Apr 11, 2019Explorer
Kamphiker wrote:
I was able to use coat hanger wire and grab the 2 wires and pull close enough to opening to run test on the ground side and there is continuity from this point to the lights etc.
Tracing from this point to the grounding source is my next step but I'm not going to put a lot of effort as the Bundles of wires in the harness is vast & runs in 2 different directions.
Wow, if I had to guess, I might say you NEVER had a good ground from that wire. That perhaps you were always just pulling the ground from the fan mount (mounted into metal?).
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
