dougrainer
Jul 13, 2020Nomad
Thorshegoes wrote:
Hi Doug, I made sure ribbon connectors are secured. Think it might be a faulty control board?
No, as much as I hate to say this. It is probably a GROUND(Negative) wire issue. HWH runs the grounds for the complete system to the Hydraulic Pump. You will see various WHITE wires connected to one of the 2 mount bolts that mount the pump to the steel mount frame. Make sure those white wires are all installed on that one bolt and that that Bolt is TIGHT. BTW, 11.9 volts is NOT good. You should have at minimum 12.6 to 12.9 volts. This indicates marginal battery, especially not fully charged. What service did you have done? Doug
PS will leave post because it has good info for someone else
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
