RoyB
Jul 13, 2016Explorer II
Did it just happen or has it been this way since day one..
Some TV setups has a wall plate next to the OTA TV WALL PLATE that has only two TYPE F connectors on it. This may require a junction cable to be installed to tie-in the bedroom TV... If you do have one of these junction plates then this is an excellent place to hookup a test RG cable to see if the wiring is good all the way to the bedroom TV set...
Might look something like this...
Who knows how the TV RG cables are wired in the trailers... Your best bet is just run a new cable if you have to. We have run all kinds of Ham Radio and Scanner radio RG cables using the foam cut Air Conditioner ducts that runs from one end of the trailer to the other. Ours have over head cabinets on both ends so makes it easy to route out of the overhead A/C ducts and route to TV location.
If you do this just be sure to seal any holes you made with FOAM SPRAY as the Air Ducts are planned to hold pressure to make all of the A/C outputs in the ceiling produce roughly the same air flow...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
