Old-Biscuit
Jan 22, 2014Explorer III
Parasitic draw(s) causing battery drain which causes increased charging......so the 'Smart Charger' probably wasn't going into float mode much.
Need to hunt down the parasitic draws and isolate them.
Hopefully you are keeping up on battery water levels.
And check each cell with a hydrometer making sure you don't have a weak/dead cell.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
