doughere
Jan 23, 2014Explorer
I wouldn't get new batteries until you've checked the convertor output; it might be the root problem. Clean up the terminals. I would make sure everything's set to go and then see if there is a problem with the battery; can your battery supplier do a load check; maybe they're OK.
GC-2 is a generic term: Usually refers to something based on the Trojan T-105; 6 V, 220 AH range. Lots of opinions on which is best, they're all pretty much the same (my 6 year old no-name specials are doing just fine).
Doug
Doug
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
