teksavy's avatar
teksavy
Lots of battery corrosion- HELP!
Hi:
I'm hoping the folks here could help me solve my problem.
Ever since I have had my toy hauler, I have had problems with battery terminal corrision. I assume this was being caused by outgassing from my two deep cycle interstate 6v batteries wired in series.
I used to keep my RV plugged into a 110V outlet to keep the batteries topped up with the internal charger/inverter built into the RV.
After talking to my local battery supplier he suggested the batteries are being over charged by the internal charger and I should purchase a NOCO Genius G3500 "Smart charger" since it will turn completely off and float charge to keep from overcharging the batteries.
Well the picture below is the result of having this charger on my batteries for 6 months. Note the completely eaten away battery charger clips.
How do I prevent this and how do I properly keep my batteries maintained?
Thank you!
-Ed
  • Parasitic draw(s) causing battery drain which causes increased charging......so the 'Smart Charger' probably wasn't going into float mode much.
    Need to hunt down the parasitic draws and isolate them.
    Hopefully you are keeping up on battery water levels.
    And check each cell with a hydrometer making sure you don't have a weak/dead cell.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
