dougrainer
Mar 10, 2020Nomad
steelshooter wrote:
Doug, Was able to find the box causing the buzzing. Looks like something you were refrencing. The box does split the stop and emergency lights to make the 3rd stop light work. I dont really know why it is there, I am not seeing it on new campers.It doesnt look like GM is going to be able to tell me what was done to cause this to happen with the new truck. I am either going to have to put up with it or rewire the lights on the camper.Thank you for responding. Larry
It is there, because if NOT INSTALLED, every time you turned on the Left or Right turn signals, the center Brake light would come on and flash also. The diode "Sees" that BOTH left and Right brake lights are engaged at the same time and then routes the 12 volt signal to the center Brake Light. If it only sees 1 turn signal, it knows to not power the center light. Read This link for better understanding. Doug
https://www.etrailer.com/Wiring/Tow-Ready/118158.html
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
