BFL13
May 02, 2013Explorer II
Don't forget that low angle sun is when it is in atmospherics up to say 15 degrees altitude, so even if your panel is great at low angle stuff, it doesn't matter because the light is going through haze etc.
That is why they usually define the solar day as from mid-morning to mid afternoon.
You can do a bit more if you can squeeze out every little bit, but it doesn't come to many AHs out of your whole day.
Another example is with my "tracking" contraptions. It isn't worth the bother of tracking all day. Three moves a day gets almost as many AH due to the panels being able to get fairly good input off angle between moves.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
