CA_Traveler
Apr 07, 2014Explorer III
Check for 12V on both sides of the headlights and if present it's a grounding problem and track down the ground wire. Could also be a relay stuck on high beams or a loose low beam wire.
Side marker flashing may be OK. It's a common scenario for the side markers to flash the opposite of the turn signal lights. Given that type of wiring it should be the same with the em flasher.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
