- darsben1Explorer
n7bsn wrote:
I've used the Low Clearance POI file in an older GPS, the problem I had with it is that it warns you about a low clearance with-in say 1/4 mile
But it doesn't tell you the low clearance is on the side-road about to pass under the freeway (as one example)
That is the way it used to be.
On the new tom tom you can tap the screen to see exactly where it is - n7bsnExplorerI've used the Low Clearance POI file in an older GPS, the problem I had with it is that it warns you about a low clearance with-in say 1/4 mile
But it doesn't tell you the low clearance is on the side-road about to pass under the freeway (as one example) - darsben1ExplorerOKay see your private mail
- danorenExplorer
darsben1 wrote:
I see the unit in your signature. Is the file in OV2 format and do you have the MY Drive program on your computer?
I do have MY Drive program on my laptop but no file on OV2, how do I do that? - darsben1ExplorerI see the unit in your signature. Is the file in OV2 format and do you have the MY Drive program on your computer?
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
