old_guy's avatar
old_guy
low electrical volts
I have my TT sitting next to the house with 30 amps supply line to it. I was in the TT today and the only thing running in the TT is the frig. I turned on the A/C and the voltmeter went into the red. I know that is not good esp for the A/C motor. I checked the fuse box in the house, and the guy who put in the service to the TT used two 30 amp Square D fuses. none are tripped and I don't know why the gauge would show in the red. do you think the two fuses are going bad or just not working properly? Any suggestions. Thanks
    I think this is your problem.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    It is also suspicious he used 2. 30 amp service only needs one (120 volt) unless you have a 50 amp outlet.. I know when I had a house the outlet was bigger than the breaker.. but that was MY choice.
  • What was the actual reading?
    I had one of those square, analog meters and it's read zone was overly sensitive to what's bad - I think it said 110 was too low. Also, it was very inaccurate compared to my calibrated Fluke. Ended up tossing it.
    If it's over about 106VAC, it's fine.
    This is all assuming you have a normal 30A service. If you really have two breakers on a 120V 30A service then your toast. Time the for electrician to pay up for repairs.
  • It is immediately suspicious of 2 FUSES (I think you mean breakers, but we work past that for now), because your TTs 30amp feed should only be 1 (One) 30amp breaker.
    It sounds like you are not tuned to electrics, but you had best find someone that is right now. I am going to suggest that you find out what is going on.
    If your electrician made the common (way too common) mistake, it could have already done a great deal of damage to anything connected. Many electricians, it seems, never read either the receptacle itself or the code about a TT30. The TT30 (two slanted blades and a round ground pin is a antique standard that got grandfather in and is still in use though it meets none of the modern standards. Many electricians assume that because the two blades are the same, it is a 230V connection. (Like a clothes dryer might be.)
    Good luck, I hope I am wrong about the damage.
    Matt
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 31, 2025
