nomad2013's avatar
nomad2013
low flow from toliet hose
The water flow from the sink is normal. However, when using the toilet hose into the bowl, the flow is low, but usable. We have been on the road for several months & this is the first time we have seen the problem. We are on a military base with full hookups. Any ideas what the problem could be? Thank you in advance for your help!
  • While you have the sprayer part off of hose........hold the lever open with a rubber band and then soak the whole sprayer head in a jar with white vinegar.
    The small sprayer head holes can plug up real easily
    Also..hold the hose end inside toilet bowl and give it a good flush by using the toilet hand/foot lever to spray water thru the hose.
  • nomad2013 wrote:
    What would I be looking for at the screen?
    Small pieces of gravel, sand, calcium build up... same sort of stuff that you find in the faucet aerator/screen when it clogs up.
  • unscrew the wand from the hose ,there could be a screen in there , even at the supply end of the hose.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
