GlennLever
Feb 27, 2014Explorer
Mandalay Parr wrote:
Maybe you can install a regular gauge.
If it ever warms up here,-5 tonight and that is not wind chill, I will run a separate ground to the gauge, check for corrosion on the terminal of the sender, and then if all else fails replace the sender, and then the gauge to see if I can get it to work.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
