robatthelake
Mar 13, 2014Explorer
On Our C-8.3 I too get the "low pressure" at Idle alarm from time to time after a steady drive at Highway Speed.
i took it in to Cummins West in Bakersfield to have it checked . They attached a manual pressure guage to a port on the left side of the block ,just a few inches along and easily reached from the rear Engine Hatch.
The prognosis was that the Engine Idle Speed was too low . The Mechanic increased the idle speed which cancelled the alarm.
They stated that it was a common issue ,but wasn't a problem because the lmanual guage indicated that there was sufficient oil pressure.
The minimum pressure is 750 PSI
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
