tpi
Mar 17, 2014Explorer
If it were mine I'd confirm the hot idle readings with a mechanical gauge installed temporarily. It appears the shop already did that and said it is normal. I'd believe him.
You may want to install a new sending unit in case yours is a bit out of spec. Just for your comfort level.
Over the years I've had quite a few engines with oil pressure on the lower side. They have been stable and without exception run just fine till I sold the vehicle for other reasons.
You are lucky you have a gauge that actually works. I have a dopey Ford oil pressure idiot gauge on my motorhome, and a dopey Nissan idiot gauge on my Frontier pickup. These gauges stupidly point to 2/3 scale any time the engine is running and develops over about 6 PSI oil pressure.
