Davidlee64's avatar
Davidlee64
Low propane indicator?
I have 2 propane tanks with an auto switching regulator. The regulator does exactly what it is designed to do. The only bad part is I don't know when it switches unless I go outside and check it daily. That could be risky when it's cold outside as I wouldn't know how long it had been on the backup tank. The other day I switched it over, didn't have a spare tank, and ran out before I could get tanks filled. What I need is some sort of gauge or indicator that I can wire up to something inside the RV that I can glance at. The only other option at the moment is to leave #2 tank turned off until needed. Then replace empty, and have at standby. The bad thing would be the furnace quitting from lack of propane at 3 am and 35 degrees outside. Anyone have any suggestions?
  • I have been fine with the indicator on my regulator. Yes if the furnace is running day and night the indicator needs to be checked daily. And check it early enough that you still have time to run out and get propane. If your schedule is that crazy you may need a third cylinder to swap in and refill next day. I do far prefer the indicator on my replacement Cavagna regulator.
    Costco.com has a good price on 30# cylinder.
  • brulaz wrote:
    time2roll wrote:
    lp-tank-check-gas-level-kit-monitor
    :E
    Very nifty.
    Do you have experience with this?
    I have these on three tanks and my experience has not been good.
    I have a tank for my home barbeque that has one with a full tank of propane and a new battery in the sensor that indicates the tank is empty.
    They seem to only work part of the time.
    I would not recommend plus they are a little pricey.
  • If you can find one, the Marshall Gas Controls RCI-24 Remote Changeover Indicator is an easy add-on if you have or switch to a Marshall series 250 automatic changeover regulator. It's a simple LED device that lights up when the changeover occurs, and can be mounted inside your RV in a convenient location.
    MARSHALL ACQ Remote LP Changeover Indicator
  • Do a search for LP Remote Change-Over Indicator, there are some that work.
  • You should be able to trust the auto switch over valve on the regulator. Do your due diligence and look at your tanks daily. Leave both tanks open at all times, indicator pionted at only one.
    The best guage of partial tanks level in cold weather is to pour a glass of hot water down the side, feel with your fingers where the temp. diff. is, that is your liquid propane level. In hot weather, use iced water! Do not trust the frost line, it may be yesterdays
    Propanes vapor, boiling point is -44.3 f. As you demand it to boil off, the liquid chills, lowering the temp and volume it can vaporize. When it can no longer vaporize fast enough to meet your demand, the regulator will signal 'Empty' even when it may not be, due to the nature of the fuel.
    Its physics 101, no other scheme will do unless you have float levels in the tanks.
    Pressure is relative to temperature and demand.
  • I don't think wiring up electricity to highly flammable propane is the answer. There are gauges you can install but you'll still have to go out and check them. Unless you're in snow country and keep your trailer at 85*, a tank should last a few days or longer.
Having RV issues? Connect with others who have been in your shoes.24,301 PostsLatest Activity: Aug 15, 2025
