1duckie4u's avatar
1duckie4u
Low water flow-pressure ok
Have low water flow when hooked up to city water, especially hot water. Accidentally found out that when the toilet is flushed or any other faucet opened, even for just a second, flow is great. I can't figure out what it could be. Maybe an air lock? Would appreciate hearing from anyone else who has had this problem and how they fixed it.
  • DO you use a water pressure regulator?
    It could be static until higher demand then it opens up
    OR
    The check valve inside city water connection is cocked restricting flow until higher demand moves it farther open
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
