MrWizard
May 13, 2014Moderator
Mexi
The bell curve is not a wattage point, it's a voltage point
Mppt will convert any voltage higher than the the. "Charge set points" to extra amps
The higher the voltage difference applied to the controller, the more amps gained at the max charge set point
Take the number of watts you want, then price the system cheap panels with pricey controller
More costly low voltage panels, with cheap controller
There is no break over point (bell curve) that , I am aware of, for figuring out which one too use
Too much fluctuation in the market in pricing of panels,
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
