MrWizard
May 13, 2014Moderator
That's a theoretical 28.98 amps at 13.8v
But that is a reality check of 22.85 output from panels at 17.5 volts
Panels tilted for max power, A 25amp PWM controller will give you max 20~22 amps if the batteries can use it and the Sun is right
But to get the full 400w aka 29 amps charge into low batteries you will need mppt
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
