dbbls
Apr 10, 2016Explorer
First of all, you will never be running at full load all the time. If you are not going to run both AC's at the same time, why go with a 5500 watt gen. A 3600 propane unit will provide 30 amps of service. It will use less fuel than the 5500. You will probably not run the gen overnight either. Too noisy right below the bed. Plus the propane you use will go a long way on park rent.
