Kayteg1
Apr 11, 2016Explorer II
Lantley you have valid point that in the weather you used to drive - cooling 5er with 2 AC might not be a problem, but just beware that once in a while you might run into such weather, so don't take the procedure for granted.
Generator fails, AC fails, thermostat fails, s***t just happens.
Beside, when you use 6 gallons of propane to cool down 5er so you can go for lunch, the cost of running will exceed dog lunch at restaurants ;)
