Johnny_HurryupExplorerAug 25, 2019LP generatorsRoughly, how much propane does an LP generator use in say, a 12 hr period? I'm thinking of buying a Class C with the 6 cyl diesel and some of those coaches only carry 12 gal propane tanks,
12 RepliesReplies sorted by NewestShow MorePNW_SteveExplorerAug 25, 2019About 15% more than a similar gasoline generator would use under the same load. Seriously, You have not given nearly enough information to be able to give you a meaningful answer. What size generator?Inverter or fixed speed? What loads are you supporting?pianotunaNomad IIIAug 25, 2019Propane generators are quite thirsty. 3.44 gallons per hour is possible depending on the size of the generator and the load.https://generatorpowersource.com/best-propane-generators/A 4000 watt at 50% load may consume about 4.8 gallons in 10 hours.Propane is a LOT harder to find especially for a fixed tank installation.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
Related ContentGenerator noise reductionGenerator operationonan 2500 lp generatorLP Generator Starts then StallsDiesel or LP generator
