Our new motor home is equipped with an LP (low pressure) quick-connect to be used with a portable grill. I was told all I need is a quick-connector and hookup directly to the grill. That means I d...
Just get a Camco Olympus grill on Amazon. Its a portable low pressure grill. Or see YouTube for how to convert. Walmart sells an $11 part that replaces the high pressure reg control if you want to convert a weber Q. Here's the part at Camping World although Walmart and Amazon have it too. If you need the hose, it's available also. Quick Connect to convert table top grill with regulator to a quick connect unit that uses RV regulator.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
