Our new motor home is equipped with an LP (low pressure) quick-connect to be used with a portable grill. I was told all I need is a quick-connector and hookup directly to the grill. That means I d...
You should have a model 250 (standard since '04), it should be stamped into the female, one of the other versions is Model 5LP (used for high pressure).
