Our new motor home is equipped with an LP (low pressure) quick-connect to be used with a portable grill. I was told all I need is a quick-connector and hookup directly to the grill. That means I d...
If you are going to keep the regulator on the grill you will need a setup like this. If you tr to run grill on low pressure side of RV regulator and also use grill regulator you will have a low flame. I got all my parts at Tactor Supply.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
