MizzouriExplorerJan 16, 2014LP GrillOur new motor home is equipped with an LP (low pressure) quick-connect to be used with a portable grill. I was told all I need is a quick-connector and hookup directly to the grill. That means I d...Show More
MizzouriExplorerJan 18, 2014Thanks to all of you. I know the direction to go now. RV.net almost always has the answer.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
Related ContentLP extension for grillLP Grill ConnectionAttaching Blackstone grill to RV LP accessory connectorQuick connect LP fitting won't work with standard gas grill?Small Grills
