MizzouriExplorerJan 16, 2014LP GrillOur new motor home is equipped with an LP (low pressure) quick-connect to be used with a portable grill. I was told all I need is a quick-connector and hookup directly to the grill. That means I d...Show More
DUNEBUGGYDOUGExplorerJan 18, 2014Simple solution, get a grill that uses the screw on cannisters and be through with it .No muss, no fuss
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
Related ContentLP extension for grillLP Grill ConnectionAttaching Blackstone grill to RV LP accessory connectorQuick connect LP fitting won't work with standard gas grill?Small Grills
