OasisbobExplorerOct 12, 2017LP PRESSURE ?Recently noticed the high output burner on my stove is a tad loud and there is a section of openings that do not light on the burner. This moves if I gently blow on them. Also oven pilot has phases...Show More
Old-BiscuitExplorer IIIOct 12, 2017When was last time you CLEANED burners....toothpick openings to clear them and clean out burner gas tubeRV LP Pressure is 11" WC (that is roughly 0.4 psi)A Manometer is used to measure pressure.....connected to gas appliance and then at least 50% of propane appliances in serviceHow is Water Heater Flame?The Furnace?Fridge?OTHER stove top burners?Could be dirty stove top burner, could be range/oven regulator or could be LP Reg (IF other appliances have issues)
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
Related ContentLow LP/Propane pressureLP Gas pressure at refrigeratorTire Pressure?Tire pressuresTire pressures
