I am replacing the Propane regulator on the motor home and have one question. The new regulator has in and out ports that seem easy to install but the regulator also has a plastic plug above the ve...
You should be installing a horizontal two stage regulator and the vent should be facing down. Plastic cap in most cover the adjustment screw. It should be preset, so don't play with it!
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
