I am replacing the Propane regulator on the motor home and have one question. The new regulator has in and out ports that seem easy to install but the regulator also has a plastic plug above the ve...
Just for other interested thread followers, some of the newer 2 stage regulators are coming through with a 1/8" pipe thread plug in the upper area of the second stage area. This is so a fitting can be installed temporarily to check or adjust the actual output of the regulator. We had a regulator fail about 3 weeks ago and the new one was so equipped. When I checked the old one it was only putting out about 7" WC of pressure instead of 11" WC. And yes, I do have a gauge.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
