joraz's avatar
joraz
LP vs. Gas
I'm thinking about buying another rig (sold ours six months ago). This rig is a GMC (1976) with an Olds 455. It's low mileage and has only run on LP. I've got a couple of questions:
1. Other than it being less efficient are there any negatives associated with running on LP?
2. In that this rig has been running only LP, other than rotted gas line, what other problems might I encounter?
Thanks.
jor
  • I used to have forklift with Nissan engine converted to propane.
    That thing was about 30 years old, sitting for 6 months at the time, yet starting after couple of seconds every time, beside the time when I wash the engine and got distributor wet.
    Good part of propane is that is not aging, what on rarely used forklift was big plus.
    Negative part it was hard to start in cold weather.
    I know professional systems in cold weather use gasoline to start and after the engine reaches certain temperature, it switches to propane.
    Modern car conversion in Europe runs about $3000
  • dougrainer wrote:
    ...Are you positive that it has been outfitted to ONLY run on LP...
    Doug,
    The OP included, "other than rotted gas line" was the clue that it had been run on gasoline originally.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
