joelyn's avatar
joelyn
LT265/60R20 Tire PRESSURE??
anyone running the above listed tires on there lt duty trucks? if so what amount of air pressure are u running for everyday use, no loads or towing? tire rated for 80psi but seems a little to much for normal driving conditions. Any suggestions on a psi for normal driving? load E range 10 ply and truck is a ram 2012.
  • DrewE wrote:
    What is the weight on the tire? Single or dual rear wheels?
    If you know the axle weights, you can look up in a table from the tire manufacturer (or really any maker of the same size and type and weight rating of tire) and see what the appropriate inflation pressure is for your weight. 80 psi would only be appropriate around the maximum rated weight capacity of the tire, which I'm pretty sure you're nowhere near in everyday running around.
    If you don't know the axle weights, the door sticker would give reasonable information for the maximum payload of the truck, if these are the stock sized tires for the truck.
    weights off the weight chart fothe 2012..
    Curb Weight
    5,342 lbs
    Gross Vehicle Weight Rating
    6,800 lbs
    Max Payload
    1,458 lbs
    hope this helps
  • DrewE's avatar
    DrewE
    Explorer III
  • Not that tire but a lot of people run the 80# tires at 65# if your tpms system will allow it without an alarm.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
