MEXICOWANDERER
Nov 24, 2015Explorer
DATE CODE - DATE CODE - DATE CODE
Many sit for a long time although Mazatlan has some 18 hole courses in the zona dorada.
Like it or not LTH produces thousands of GC220's for re-branding in the USA market.
In Mexico, battery warranty must be done in the same exact store you purchased them.
Warehouses are referred to as Proveedores. (pro-vey-DOORS)
Auto parts stores are called Refraccionarias (ray-fraction-EE-own-AH-REE-ahs)
Date Codes...
Alpha-Neumeric
A5 (Jan 2015)
G5 (Jul 2014)
Most month abbreviations are comprehensible (Feb, Febrero, July, Julio) except for January (Enero).
Los Paginas Amarillas (The Yellow Pages)
Will list autp parts stores, and warehouses. Look for "Distribudor Authorizado" in an LTH logo.
Baterias para carros de golf, seis voltios, is the way you ask for GC220's.
Count on the LTH and anything else you'll find down here as being 208 amp hour batteries. Nothing wrong with them at all, if they haven't spent eternity on somebody's stock shelf.
I would not accept a GC220 that measures voltage lower than 6.25. Cherry pick your batteries. The higher voltage the better.
Distilled water IS NOT AVAILABLE DOWN HERE and when you do run across it, it is usually stupidly expensive. "Purified" water is a long way from distilled but for one or two top-off's, it'll have to do.
Top Charge those batteries before you put them to work. This is one time Top Charging is vital to ensure good battery life.
LTH is located in Monterrey, Nuevo Leon.
Hope This Helps
Date Codes...
Alpha-Neumeric
A5 (Jan 2015)
G5 (Jul 2014)
Hope This Helps
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 27, 2026
