pianotuna's avatar
pianotuna
Nomad III
Jan 01, 2023
LTO batteries
Hi all,
It looks as if LTO batteries are becoming available.
I've written to the company below for pricing on a 100 amp-hour nominal 12 volt battery.
They can be charged at 10 C. (i.e. 1000 amps)
They work from -50 c (-58 f) to 60 C (140 f)
The cycle life is 30,000
Assuming a 100 amp-hour jar:
They can be drawn from at up to 10 C (1000 amps or 12000 watts)
They can be drawn continuously at 3C (300 amps or 3600 watts)
It seems to me that they would be a great choice where battery space is limited.
https://www.osnpower.com/12v100ah-lithuim-titanate-battery-lto-12v100ah-deep-cycle-life-12v100ah-lithuim-battery-12v-100ah-lto-battery-pack_p228.html
from OSN POWER
Anyone know much about them?
https://www.osnpower.com/lto-batteries_c10
  • Since they are rated to 10° F and use with "electric skateboards"
    I would make sure they are "Thunder Proof"
  • pianotuna wrote:
    Hi all,
    from OSN POWER
    I'd also ask about the physical size of a 100 amp hour 12V battery. Since it appears that the energy density is close to 1/3 that of a standard lithium battery, it may be impracticably large.
  • 3_tons's avatar
    3_tons
    Explorer III
    FWIW, I came across this link:
    https://climatebiz.com/lithium-titanate-batteries/
    3 tons
  • Some are not as specific but I think the primary use is for start batteries due to higher discharge rates and low temperatures.
    But seems OK with deep cycling.
    I am curious about how the start batteries and alternator work together.
  • 3_tons's avatar
    3_tons
    Explorer III
    An ‘independent’ (objective) white paper would be useful.
    3 tons
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Thermoguy wrote:
    Looks like a Chinese packager or Li-Ion batteries. They take the cells and package them in different configurations for different applications. I have no experience.
    They do make LiOn and LiFePo4 but LTO is a different battery.
    https://en.wikipedia.org/wiki/Lithium-titanate_battery
    I would be very interested both 100 AH and around 24AH prices.
    Also charging specs. if the OP can respond when the company gets back with them.
  • Looks like a Chinese packager or Li-Ion batteries. They take the cells and package them in different configurations for different applications. I have no experience.
