John_Joey
May 30, 2015Explorer
desertmoose wrote:
I considered a spray silicone, but if it gets into the valve, but would it probably get into the water tank also?
Thanks, Sam
That's what I do. If it could get into the water then you would have a leaky drain since water would be coming out the same way the silicone would get in.
The real answer is if you can take the drain apart after a little silicone, then use some plumbers grease on the O ring.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
