bandit86ExplorerJun 14, 2016Lubing leaf spring pivot pointsJust changed all the plastic bushings out today on both axles. Lubed them up with antiseize in and out. Going to stick to my trust mixture of gear oil and grease to lube them on a regular basis. It g...Show More
time2rollNomadJun 14, 2016I installed greasable bolts.http://dexteraxle.com/heavy_duty_suspension_kits
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related ContentLube points etc. w/regular maintenance ? E-450Jack LubeToilet seal lube?Roadmaster RR10 lube point chart??EZ Lube/Ultra Lube
