Stevewb's avatar
Stevewb
Lube points etc. w/regular maintenance ? E-450
on my 2015 Ford E-450 I would like to find a schematic or info on lube points (zerk fittings etc.) that should be attended to on a regular basis...
On my old Class A Ford F53 chassis there were quite a few lube points to service, front end-drive train and so on...
I do not trust oil service shops nor even Ford service to know or even care if this service work is properly done, this comes from experience with shoddy work done by so called Authorized Ford RV shops...
What it comes down to for me is being resposible to learn as much as I can about my rig and taking appropriate action to getting the job done correctly..
Thanks.
  • BruceMc wrote:
    ---words deleted----
    Now that we have a new Chevy 4500, I'll explore & find the maintenance points.
    Cheers!
    The Chevy will likely have 11 fittings. There is an idler arm, 2 center link, 4 tie rod, and 4 ball joints.
    * Altogether, there are four ball joint fittings, four tie rod fittings, two center link fittings, and the idler arm fitting, for a total of eleven.
  • Looks like 4. One on each joint and one where the tie-rod connects to the drag link:
    I didn't find any other zerks on our E350; I expected to find them on the u-joints and perhaps the center carrier bearing, but they are all "Sealed for life" devices.
    Cheers!
  • If you have the plugs, take a good look at grease gun access to a replacement zerk. You can get straight zerks or angled ones. I think I used two of each. They are about 50 cents apiece so you know what to do.
  • j-d's avatar
    j-d
    Explorer II
    X2
    X3
    The Fords used to have grease fittings on the ball joints. Then no fittings but there was a threaded plug and we could install fittings there. The latest ones are totally blind. No threads, no plug, no hole. Our axle is 2012 and it's like that. I don't know when fitting hole plugs went away.
    Yes, our 2002 E450 has a 2012 axle. Another subject...
  • Steve GOOGLE your MH lube location and it tell you all. JMO
  • When you pump the grease in do not try to inflate the boots, 2 or 3 strokes is all you need, many times to much grease is pumped and the boots are stressed which leads to premature failure.
    navegator
  • Bobbo's avatar
    Bobbo
    Explorer III
    There are 4 lube zerks. One on each wheel spindle, and two on the tie rods.
    (I hope I got the terminology correct. I am NOT a car enthusiast.)
    This You Tube video actually is pretty good at showing the locations. DON'T GREASE UNTIL IT BURSTS THE BOOT! When the boot starts to swell, stop.
    https://www.youtube.com/watch?v=Fq9wRaYclz4
