down_home
Aug 16, 2019Explorer II
At a Gun shop buy CLP. It penetrates cleans and lubes, and protects from rust.
About 10.00 for large spray can. Spray it in or on, let set for a few minutes and spray with more. after a good while wipe off excess that there might be.
We use it on firearm all the time and used it on our garage doors a month ago when freeing it up.
On our fifth wheel it wasn't the landing gear that gave us problems as it was inside the Fifth Wheel but the rear jacks. Road spray and the more dirt the worse. Every time I set up, just about I had to use water under pressure to clean it off then sprayed them with silicone.
Silicoen might be the better option you jack after it is cleaned up or out. Something dry won't hold as much dirt.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
