sandy43's avatar
sandy43
Lubricating slide seals and flaps?
What do you guys recommend for keeping the rubber around the slides in good shape? Thanks
  • milo's avatar
    milo
    Explorer II
    tandkj wrote:
    I use the spray foam stuff in the red can to lube and clean the seal flaps.
    Cuse me sir. I Googled "spray foam stuff in the red can" and nuttin but foam insulation popped up. Would you mind telling what spray lube you use comes in a red can. Inquiring minds want to know.
  • I use the spray foam stuff in the red can to lube and clean the seal flaps.
  • If you are referring to the rubber wipers, not seals, on the outside of the RV any good rubber protectant such as 303 works fine. If you mean the seals which are on the inside, talcum powder works great to keep them from sticking. The rubber wipers are designed to clean the slide as it retracts.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
