cj99's avatar
cj99
lug nuts cracking
So like the title say I just wanted to bring this up for you all to check your lug nuts next time you pull off a tire. I had a blow out about 2 weeks ago on my 2012 road warrior and when changing the tire I noticed the lug nuts ( all most all of them ) had started to crack down the side.
This is not a concern of the tire/wheel coming off as with these lug nuts are 2 piece ( when they are made ) and worse case if you have them crack too much you wont beable to get them off in order to change a tire. So being I had stock / factory 2012 tires ( made in 2011 on the tire code ) my blow out was one of those not caused from road debris but looked like the steel belting came apart so I cant trust the rest of them so I was in the middle of changing all 6 at home and notice the cracking issue. I posted this not because of one bad lug nut but I had to order 48 of them and I would say almost all of them were cracking some bad.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
