ScottnSherrie's avatar
Oct 06, 2013
Lug nuts stuck
Trying to get left rear duallies off to work on brakes. Using a cheater bar, I busted the truck wrench that came with the RV. I about to call a local truck place and see what they would charge to come out and just get the lug nuts loose. My other plan is to buy an indestructible lug wrench.
Suggestions welcomed.
  • Sometimes the left (driver side) wheel nuts are reverse thread. Double check for that. Don't use a torch to heat the nuts, the heat can spread to the wheel and cause the tire to explode.
    Brian
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
