Kayteg1 wrote:
toedtoes wrote:
I looked at the SS, but found I would have the same issue as I did with the slinky - it wouldn't push everything through the line. If you have a clean out close to the RV and no/few elevation or turns, then it's a good option.
If you have elevation and/or turns to reach the clean out, then the macerator is much better suited.
Everything has its limitation.
I own my SS for about 15 years. Used it on my rental for semi-permanent use with over 100' of 3/4 plastic pipes extension. Never had a problem.
Than at my California house I had 150 psi city pressure and SS could do really amazing things.
I had macerator pump left from spare from my conversion, but sold it as I did not need high lift and potential for STINKY problems is just too big.
You can read lot of horror stories about macerator pumps at boat forums.
I agree each has its limitations and positives. When I made my decision, it really helped to understand why others chose one over the other. It made figuring out which was best for my situation much easier.
Either way, I will never go back to a stinky slinky.
