dougrainer
Jun 24, 2020Nomad
traildog wrote:
I called my electrician brother and he was stumped
As well. He asked me if all power had been disconnected while installing and after installing the capacitors (I replaced both).
I disconnected all power including the battery and waited for an hour. I fired it back up and now it’s running correctly.
Fluke? Maybe but, it was the suggestion from my brother that save me from buying more unnecessary parts.
Thanks for the help here.
TD
Disconnecting 12 volt and 120 power had NOTHING to do with fixing your problem. ALL a capacitor does is BOOST the start up needed power. Did you ever check the separation gasket like I asked? Doug
