traildog
Jun 27, 2020Explorer
wa8yxm wrote:
Ok now I know Coleman's Suck. but that's the CONDENSER side of things (Outside) where as most A/C's blow.. And I think I FINALLY figured out why but that is another thread.
But inside is a squirrel cage blower or so I thought, you turn those puppies backwards they just don't blow they do not blow the wrong way. they just don't blow period.
Sounds like you have a baffled baffle or someone installed something cattywompus
Specifically.. the ceiling cover
The air intake is normally toward the FRONT of the RV and the output to the back. if someone installed the inside cover and a baffle wrong... You get what you got.
This could have been the problem. Last season, before I parked the TT, there was a leak around the AC. I took all of the plastic inside off to find it and reassembled.
This year, When I found the unit to be running in “reverse“, I disassembled it again.
When I put it all back together, it’s certainly possible I rotated the ceiling cover which could have been the problem the whole time............
Live and learn.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
