72cougarxr7's avatar
72cougarxr7
Made the jump to golf cart batteries!
Decided it was time to retire my AC Delco group 24 RV/marine batteries that had date codes of 2013. Figured 8 years was a good run, and our last boondocking trip they didnt seem to last through a 3 day weekend like they used to.
Ended up going to Sams Club and getting 2 Duracell GC2 golf cart batteries for $89 each. they say on the label they are made by East Penn/Deka, and I have had great luck with East Penn in the past.
Only about $10 more than a new group 24 from Walmart, so I figured I cant go wrong!
  • They are 60-65# each. About double what a 12V weighs.
    They weigh so much mostly because they have more lead in them. This is a good thing as it means they will last longer. They are the best bang for the buck. I used them for many years.
    I recently took the plunge into Battle Borns. The price of admission is high. But the longevity should make them more economical over time.... And the bonus is no terminal corrosion, and no need to add water.
  • NamMedevac 70 wrote:
    Although I have never needed them I have heard that one battery is large and extremely heavy????
    They are 6 volt so you have to run 2 to achieve the 12 volts required for rv use.
    The GC2 batteries are similar length and width to my old group 24 batteries, but the GC2 is taller.
    They are quite heavy.
  • wopachop wrote:
    Sweet. Do you have solar? If yes you want to choose the charge profile for wet cell batteries. They get slightly higher voltage. Also benefit from the occasional equalization charge of 16v.
    No solar, I do have a Progressive Dynamics converter with the multi stage charging.
  • Although I have never needed them I have heard that one battery is large and extremely heavy????
  • That's where we go for our golfcart batteries, we spend more $$$ for gas on a single RV trip than we pay for at least 8 years of 12 volt reserves. Don't see us going to any advanced battery technology in the near future when we get great service and longevity for a few dollars annually. We did a pair of 12 volt batteries early on in our RVing experience, what a notable difference overall when we switched over to GC2 batteries as it pertains to RVing off the grid.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    150 amp hours to 220 for 20 bucks, what a deal
    and when you get to usable amp hours. it's even better
    i used DEKA as well... no complaints.
  • Sweet. Do you have solar? If yes you want to choose the charge profile for wet cell batteries. They get slightly higher voltage. Also benefit from the occasional equalization charge of 16v.
  • The price was right !
    If you take care of them like you did with the other one they should last even longer.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
