cavie
May 31, 2019Explorer
was_butnotnow wrote:
Getting high volts AC
Any ideas what is causing this.
Assuming your looking at the incoming AC power voltage I suggest you use a volt meter and go outside and plug test the voltage at your shore power and see what it reads. They should be the same.
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Apr 13, 2026
