dkreuzen
May 31, 2019Explorer
Look in your owners guide:
"High Volts AC appears on the LCD.
The FAULT (red) LED is on. The
PWR (green), CHG (green), and INV
(green) LEDs are off.
High Volts AC – This fault causes the charger to be disabled because a
very high AC voltage (>150 VAC) has been detected on the AC input.
Remedy: Remove all AC power from the inverter’s AC input for
at least 15 minutes to automatically restart this fault. Ensure only
120VAC power is connected to each of the inverter’s AC inputs."
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Apr 13, 2026
