3_tons
Apr 05, 2015Explorer III
In your RV's main panel, try disconnecting the 'neutral' wire (not the hot at the breaker) from the water heater to the common neutral bar. If this solves the problem you have leakage at the WH electrode (minerals in water bridging the element to ground - circular milliwatt path).
3 tons
3 tons
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
