pianotuna's avatar
pianotuna
Nomad III
Mar 31, 2015
Magnum Hybrid Inverter and ground fault
Hi all,
I've run into a problem with the Magnum 3000 hybrid. It appears to be tripping 15 amp ground fault outlets.
  • How is the inverter wired vis-a-vis the GFCIs? Are the GFIs connected to the output of the inverter, or does the inverter plug into a GFI protected outlet, or some more complicated scheme? Do they trip all the time, or only when the inverter is providing power?
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
